Ticking under dash
270,000 MILES • 7.3L • V8 • 4WD • AUTOMATIC
BULLITT1939
  • 37 POSTS
We can get the truck to start. Changed the fuse panel and still have same issue there is a ticking under the dash and most electrical does not work. Door locks, radio, cruise do not work, and back doors will not open. The windows do work.
May 9, 2017 at 12:40 AM
CJ MEDEVAC
  • 11,000 POSTS
Ticking may be a circuit breaker.
The Medic
May 9, 2017 at 9:16 AM
BULLITT1939
  • 37 POSTS
How would you go about checking this?
May 10, 2017 at 1:18 AM
HMAC300
  • 48,601 POSTS
check fuses under hood as some of those supply power to the area you are talking about it will probably be one of the larger fuses as fuse 50 supplies door locks. use a volt meter or test light on both sides.
May 10, 2017 at 5:24 AM
