Throttle body relearn
162,367 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
DAYLIGHT
  • 8 POSTS
My vehicle was running sluggish, when in park it would idle high then low like it was going to cut off. It ran okay but did not have much power. I checked the plugs and they were fouled, so I replaced them and cleaned the throttle body. After reconnecting the battery, I started it up and it was okay for about a minute, then the check engine started to flash then it stayed on. tried to drive it and it drove worst than it was before.
Dec 2, 2017 at 9:39 AM
  • 31,937 POSTS
What is the code set? i will need this to see what is going on.
Dec 2, 2017 at 7:41 PM
DAYLIGHT
  • 8 POSTS
There is no code. I use CarMd tester and no reading. I use same device on my other car and got a reading.
Dec 2, 2017 at 11:35 PM
DAYLIGHT
  • 8 POSTS
I am second guessing myself, but if had just changed the plugs I would not have the problem I am now facing.
Dec 2, 2017 at 11:57 PM
  • 31,937 POSTS
With light on there will be a code, you may need a different reader to try and retrieve codes. please give it a try again and get back here for further assistance.
Dec 3, 2017 at 7:39 AM
DAYLIGHT
  • 8 POSTS
Had a bad fuse. replace and scanner has a code po300.
Dec 4, 2017 at 12:10 AM
  • 31,937 POSTS
This is a random misfire code, i would re check the that the spark plugs are correct and if they are not iridium plugs that the gaps are correct, if changing the plugs is all that you have done, this is a good place to start and also check fuel pressure and if you can, a live data read to check O2 sensors are working correctly, start here.
Dec 4, 2017 at 5:57 AM
DAYLIGHT
  • 8 POSTS
Okay, I had number 5 and number 6 power pack in the wrong spots, put them were they were suppose to be, truck ran a lot better,but check light is still on. Was able to take truck to inspection lane and it passed. Check light is still on. AUTO ZONE error codes PO300,P0014 .
Dec 4, 2017 at 12:20 PM
  • 31,937 POSTS
The random misfire code is still there and the other is a exhaust cam position code
Possible causes Dirty Oil Low engine oil level Faulty Exhaust Camshaft Position Actuator Solenoid Exhaust Camshaft Position Actuator Solenoid harness is open or shorted Exhaust Camshaft Position Actuator Solenoid circuit poor electrical connection Faulty Engine Control Module (ECM)
check all tune items for random misfire code, also check for vacuum leaks, start here
Dec 4, 2017 at 7:57 PM
DAYLIGHT
  • 8 POSTS
All these issues has everything to do with relearning the throttle body?
Dec 4, 2017 at 8:51 PM
  • 31,937 POSTS
no, but you need to sort out the check light, the throttle body should just be a drive cycle,
Dec 5, 2017 at 5:17 AM
DAYLIGHT
  • 8 POSTS
will do,and thanks for your information. Get back with you soon
Dec 5, 2017 at 7:30 AM
  • 31,937 POSTS
Ok, I hope you find the problem re post if you require more assistance, that’s what we are here for!
Dec 5, 2017 at 9:17 AM
DAYLIGHT
  • 8 POSTS
Changed oil and put in a new filter and light went off. Thanks for your help.
Jan 7, 2018 at 1:39 AM
  • 55,758 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Jan 9, 2018 at 10:10 AM
