Think it may be a bad ground
125,000 MILES
JOECARVILLE
The car has been laid up in the garage for about a month with the battery removed. Yesterday I put the battery back in and when I turn on the ignition the lights flash and the horn sounds. A little more worrying is the fact that the battery starts to heat up ( you can actually hear it cook) . Could this just be a bad ground or what am I missing?
Thanks for your help in advance.
Joe C.
Jan 28, 2014 at 4:22 AM
HMAC300
  • 48,601 POSTS
cold be a bad ground or a really bad drain on it. check for both. also check tosee if antitheft is engaged.
Jan 28, 2014 at 5:09 AM
JOECARVILLE
Thanks for the speedy reply guys. It begs the question, is there a way to turn off the anti-theft other than the key fob.
Thanks guys
Joe C.
Jan 28, 2014 at 5:36 AM
HMAC300
  • 48,601 POSTS
not really that may not be the problem though. hopefully it is hooked up correctly as well.
Jan 28, 2014 at 7:34 AM
JOECARVILLE
The mystery is that the only thing that happened is that the battery was removed for about three weeks
Jan 28, 2014 at 8:46 AM
HMAC300
  • 48,601 POSTS
anytime you remove or disconnect a battery you have to reset the security system. so other things may be drawing on it as well.
Jan 28, 2014 at 10:59 PM
