the key doesn't turn on when I put on
1998 CHRYSLER INTREPID
190,000 MILES
VDDFF
the key doesn't turn on and doesn't move when I put on. I don't know why the key doesn't move when I put it to start the car. I move the sterling left and right but there is nothing. I want to know why the key is not moving
Jan 6, 2014 at 12:38 PM
SATURNTECH9
  • 30,869 POSTS
Have you tried lightly tapping on the key hole of the ignition cylinder with a hammer then trying to turn it with the key?Do you have a less worn key to try?You most likely have a bad ignition cylinder.
Jan 6, 2014 at 1:04 PM
