Heater blows cold air
195,234 MILES • 3.2L • 6 CYL • AUTOMATIC
LGRAVES
When I turn the heater on it blows cold air.
Oct 30, 2018 at 11:43 AM
JONNYB1963
  • 263 POSTS
We need some more information here.
Is the air completely cold when the engine is warm?
Do you have any overheating issues on the engine?
Do you smell antifreeze inside the vehicle or do you see any evidence of leaking?
Does this vehicle have climate control? If so does it have zones?
The answer can be one of many things lets see if we can narrow it down a bit.
for instance it could be:
Bad heater core
Bad cold air blend door
Bad Heater Control valve
low coolant
Climate control not working correctly
wiring issue
etc.
Oct 31, 2018 at 6:23 AM
  • 110,248 POSTS
As mentioned in the prior reply, it could be a few things. What I need you to do is follow this link. It discusses the issues which cause a heater not to work. Also, it shows what to check, and how to repair.
https://www.2carpros.com/articles/car-heater-not-working
Once you have had the chance to look through it and try some of the things mentioned, let me know what you find. If you need additional information for a specific repair, I can supply you with it and help you through the process.
I will watch for your reply.
Nov 1, 2018 at 9:58 AM
