Hi , my Tarago brake is not very good,done all service, all guide pins silicon slide smoothly,replace disk, replaced a new the master cylinder,bleed air all 4 wheels. No brake fruid leak . After 10 minutes drive, I touch check brake disks : 2 font disks are good hot,but 2 back disk are warm only ,not very hot like front disks . The Brake booter is seem good .No check engine light or ABS light. Look like the 2 front has more brake than the 2 back disks . Can ABS make this happen ? or can i set the balance on ABS for more pressure to the back disk ?
Or you idea please . Thank you .
Mar 1, 2026 at 11:29 PM
