Tapping or knocking noise after starting vehicle from front passenger foot well
2005 MERCURY MONTEGO
175,000 MILES • V6 • FWD • AUTOMATIC
ANDREADPAYNE
Tapping or knocking noise after starting vehicle from front passenger foot well area. The noise seems to occur everytime I start the car whether I had heat/air conditioning on last time I was in the vehicle or not. It makes the tapping noise 4/5 times then stops. Also, the temperature on the interior display panel is not accurate for either the interior or outside temperature. Any suggestions or thoughts would be appreciated? Thank you!
Oct 14, 2014 at 3:45 PM
SINBAD271
  • 169 POSTS
Check your blend door actuator motor. Inside is a plastic gear that may be damaged . Removal of the glove box can simplify the exact place of location just follow the sound.
Oct 14, 2014 at 9:35 PM
