Tapping noise from engine
2008 PEUGEOT 207
120,000 MILES • 1.6L • MANUAL
10SARAH37
I have a really loud tapping/ticking noise from my engine when idle and also whilst driving.
Jun 14, 2021 at 4:48 PM
Can you get a recording of the noise while idling and then raise the RPM a couple times so that we can hear what happens when you raise the RPM?
Then we are going to need to drain the oil and look for metal in the oil pan.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
If there is metal in the oil then we have bearing damage and the noise is a rod knock most likely.
Please let us know if you can get a recording of this and we can go from there. Thanks
Jun 16, 2021 at 8:19 AM
