Taillight not working
120,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
CAS786
Hello, my rear taillight, and dash lights are not working, however my brake light and indicator lights are working. sometimes i see the dash lights come one for some time together with my rear tail lights.
May 24, 2019 at 11:39 PM
  • 110,248 POSTS
Welcome to 2CarPros.
First, this vehicle isn't offered in the US, so my technical information is limited. However, to me it sounds like a bad ground. First, make sure the battery terminals are clean and tight, free of corrosion. Next, follow the ground wire to where it grounds on the body of the vehicle and confirm it is tight and corrosion free. Also, check the fuse box for loose fuses or ones that are damaged.
Here is a link that explains how a car's electrical system works. Take a look through it. Also, the second link explains how to check wiring and the third explains how to check the battery terminals and ground.
https://www.2carpros.com/articles/how-a-car-electrical-system-works
Do that and let me know what you find.
May 25, 2019 at 1:01 PM
