Changing the master cylinder in my Van listed above (g20), the whole system always used dot 3. so i filled the new reservoir with dot 3 and when i was about to mount it on i went to put on the cap and it says use DOT 4. why the change? the part is identical, and i am assuming because it is newly manufactured it uses dot 4, but will DOT 3 be okay in this case? for its entire life up until this point its always been dot 3.
Aug 31, 2019 at 1:24 PM
