Switching tires
125,000 MILES • V6 • 2WD • AUTOMATIC
JBRYANT0608
I have brand new tires on my 1999 Chevrolet Venture that had broken down literally the day i put the on it about 4 months ago. well, there is no fixing the van it will be taking a trip to the graveyard. My vehicle listed above is going to need new tires and i was just going to transfer tires from one to the other since the lug pattern matches up. until i was informed that if the van has drum brakes and the station wagon has disc brakes this is impossible. I have looked in many places and cant find an answer. so i'm hoping this group can help.
Dec 27, 2019 at 5:43 AM
STEVE W.
  • 15,410 POSTS
Well looking at the cross reference info I can find the Venture uses a 15 X 7 Wheel with a 40mm offset and a 5 X 115mm bolt circle. The Mercury on the other hand runs a 16 X 7 rim with a 42mm offset and a 5 X 108mm bolt circle. So the lug pattern doesn't actually match, the center hub is a different size and the rim is 1" smaller that you want on the wagon. The item about the brakes is that the 16" rims just barely clear the brakes used on the Mercury as it is a wagon so it has the larger brakes than the sedan. That means the 15" rims are not going to clear the calipers.
Sorry to be a bearer of bad news.
Dec 27, 2019 at 6:17 AM
JBRYANT0608
Not the answer i was hoping for but very appreciated!
Dec 27, 2019 at 7:36 AM
STEVE W.
  • 15,410 POSTS
Been there myself, old car had new 16 inch pricey snows, New car takes 17 inch or optional 19 inch. Sold old car to a young lady who totaled it about a month later, went to the scrap yard with new tires, made me sad.
Dec 27, 2019 at 9:06 AM
