Swapping motor question?
2015 AUDI Q5
100,000 MILES • 4 CYL • TURBO • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
If I decided to change the motor on this 2.0T TFSI motor, will any motor from an a4, or a5, or a q5 work since they are all the same TFSI motor?
And will it matter if the donor vehicle is a 2 or AWD?
Jan 26, 2024 at 5:11 AM
  • 110,244 POSTS
The engine itself shouldn't be different if it is the same size. As far as being 4wd or 2wd, the transmission will still have the same bolt pattern, so it should (in theory) work.
Let me know if I can help.
Jan 26, 2024 at 11:38 AM
