2006 Suzuki Vitara turn signals and hazard signal
2006 SUZUKI VITARA
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
MEMAH122756
ignition wasn't turned off all the way, ran battery down, then wouldn't hold a charge. Replaced battery and turn signals flashed fast inside but nothing worked outside. Hazard works inside but nothing outside. Replaced flasher and checked fuse, none blown still not working. What is the problem?
Mar 20, 2010 at 10:38 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the factory security system is going off.Have you tried locking and unlocking the drivers door with the key to see if it wil make it stop? Also try the rear door if the drivers door doesnt work, sometimes they put the master switch on the rear door.
Mar 24, 2010 at 12:23 AM
