2001 Suzuki Grand Vitara Please respond
67,000 MILES • 6 CYL • AWD • AUTOMATIC
PELUDOS#02
I am having this problem with the air condition. Three years ago it was replaced the condenser and the blower. Five month ago I had to fill it with gas. The technitian told me there was a problem with the condenser or the blower because aparently there is a leak. I said it was replaced. He said he could fill it up but I will have cool air for a time and go back to the same. It happened I turn the air condition on and it blows very subtle cool air after a while. Tell me what is wrong ?
Apr 18, 2008 at 12:18 AM
LEGITIMATE007
  • 5,121 POSTS
thats just it, there is a leak somewhere and it has to be found and fixed before it will ever work right again. what you can do is find one of these places thats doing a promotional, on air conditioning . usually they will put some die in your system and it will tell you where the leak is and that part can be replaced. or you can do it yourself , they have kits in the parts stores that you can buy and find the leak yourself . then if it is small enough there is some sealant that you can put in the system that will seal the leak, but only if its small enough, I mean pin hole small. get back to me
Apr 18, 2008 at 1:19 AM
