What does it mean when the power signal comes on?
Its right under the check engine signal only instead of the check engine signal flashing I get a signal reading "power". What could be the problem?
Saturday, December 20th, 2008 AT 6:54 PM
DAVE H
MECHANIC
Power Indicator
POWER indicator light will illuminate when ignition switch is turned to RUN position and go out when engine is started when switch is in "N" (normal) position. POWER indicator light will remain illuminated when switch is in "P" (power) position
SPONSORED LINKS
Sunday, December 21st, 2008 AT 10:45 PM
CGARCIA
MEMBER
1 POST
I have problem my suzuki has power ligth on steady
