1990 Suzuki Swift Fan Not Working
If voltage is not present at fan relay Blue wire, repair Blue wire between cooling fan thermoswitch and cooling fan relay. If voltage is present at fan relay terminal Blue wire, check relay terminal No. 3 (Black wire) to ensure ground is present. If ground is not present at Black wire, repair Black wire. If ground is present, go to next step.
Check for voltage at fan relay connector terminal No. 2 (White/Blue), if voltage is not present, check fuse link "B" and in-line fuse under dash (next to junction box). If voltage is present at fan relay terminal No. 2, check for continuity between fan relay terminal No. 4 (Blue/Red wire) and fan motor connector. If continuity does not exist, repair Blue/Red wire. If continuity does exist, replace fan relay.
Cooling Fan Thermoswitch
Remove thermoswitch from vehicle. Using ohmmeter, ensure continuity is correct between wire connector and thermoswitch body at indicated temperatures. Thermoswitch may be gradually heated in water for testing.
Suggested Repair
Trace the cooling fan relay circuit: confirm voltage on the blue wire from the thermoswitch, ground on the black wire at relay terminal 3, and voltage at terminal 2 (white/blue), including fuse link B and the in-line fuse by the junction box. If those are good, check continuity of the blue/red wire to the fan motor and replace the relay if continuity is present. Also test the thermoswitch for correct continuity as it is heated.
Conversation Summary
The owner of a 1990 Suzuki Swift GTI with a 1.3L DOHC engine reports the radiator fan does not come on. A previous owner had wired it oddly with a switch; reconnecting the wiring did not restore operation, and the circuit appears tied to a nonworking horn. The fan runs when powered directly from the battery and the fuses check good. The expert outlines relay voltage, ground, fuse-link, and wire-continuity checks, then thermoswitch continuity testing, with relay replacement if the circuit checks out.
