brake light (in dash)
SUZUKI
CANNBUDO
99 suzuki vitara. 80k miles. brake light comes on intermitantlly. Fluid level is full. Float in master cylinder seems to be working freely. When light is on disconeccted wires to float and put them togeather. (harness side.) light stays on. checked all fuses with test light. all test ok. no fuses feel loose. and there is no aftermarket wiring connected to fuses. Suspect pressure differential in hydraulic system. Haven't bleed system. Do you have any sugesstions? No leaks in hydraulic system found.
Jun 28, 2007 at 1:31 AM
DAVE H
  • CERTIFIED EXPERT
  • 13,384 POSTS
replace the fluid level sensor
Jun 22, 2010 at 2:15 AM
