1991 Other Suzuki Models cylinder not fireing
1991 SUZUKI
CHAPPIE28
Engine Mechanical problem
1991 Other Suzuki Models Two Wheel Drive Manual 100000 miles
my suzuki swift 1l ,3 cylinder's middle pot is not fireing on idle not sure if it is when its been driven as it drives ok! it also idles ok even though it only on two pots! what might be causing this i've changed all the electrics from the ignition coil to the spark plugs and have got a good spark on all the plugs it uses a lot of oil any help will be appreciated thanks
Jul 18, 2008 at 11:18 PM
