Pressure Plate and Clutch Disc Removal and Installation
Removal
Disconnect the negative battery cable.
Remove the transaxle from the vehicle. Refer to "TRANSAXLE ASSEMBLY REMOVAL AND INSTALLATION :".
Remove the pressure plate bolts and the pressure plate.
WARNING:Support the pressure plate when you remove the last bolt.
Fig. 12: Removing Pressure Plate Bolts And Pressure Plate
Courtesy of SUZUKI OF AMERICA CORP.
Remove the clutch disc from the flywheel.
Fig. 13: Removing Clutch Disc From Flywheel
Installation
Coat the spline on the clutch disc with multi-purpose grease.
Align the pressure plate and the clutch disc onto the flywheel using the clutch arbor J-42474.
Install the pressure plate bolts.
Tighten
Tighten the bolts to 15 N.m (11 lb-ft).
Remove the clutch arbor J-42474.
Install the transaxle into the vehicle. Refer to "TRANSAXLE ASSEMBLY REMOVAL AND INSTALLATION :".
Connect the negative battery cable.
Transaxle Assembly Removal and Installation
Removal
Tools Required
DW110-060 Engine Support Fixture
DW260-010 Transaxle Support Fixture
Position the select lever park position.
Remove the battery. Refer to "BATTERY AND BATTERY TRAY REMOVAL AND INSTALLATION :".
Install the engine support fixture DW110-060.
Fig. 151: Installing Engine Support Fixture DW110-060
Disconnect the transaxle wiring harness from the transaxle.
Disconnect the park/neutral position switch electrical connector.
Fig. 152: Removing Shift Control Cable Clip
Remove the clips from the shift control cable and disconnect the shift control cable from the transaxle.
Fig. 153: Disconnecting Shift Control Cable From Transaxle
Remove the upper transaxle-to-engine bolts.
Fig. 154: Removing Upper Transaxle-To-Engine Bolts
Remove the left transaxle mounting bracket. Refer to "LEFT TRANSAXLE MOUNTING BRACKET REMOVAL AND INSTALLATION:".
Fig. 155: Removing Left Transaxle Mounting Bracket
Raise and suitably support the vehicle.
Drain the transaxle fluid.
Remove the oil cooler pipes from the transaxle. Refer to "OIL COOLER PIPES/HOSES REMOVAL AND INSTALLATION:".
Fig. 156: Removing Oil Cooler Pipes From Transaxle
Remove the drive axle. Refer to "DRIVE AXLE ASSEMBLY REMOVAL AND INSTALLATION: For Automatic Transaxle".
Remove the starter motor. Refer to "STARTER REMOVAL AND INSTALLATION :".
Remove the torque converter bolts.
Fig. 157: Removing Torque Converter Bolts
Support the transaxle.
Remove the rear transaxle mounting bracket bolts (a) and damping block connection bolt and nut (b).
Fig. 158: Removing Rear Transaxle Mounting Bracket Bolts And Damping Block Connection Bolt And Nut
Support the transaxle assembly using the transaxle support fixture DW260-010.
Fig. 159: Supporting Transaxle Assembly
Remove the lower engine-to-transaxle bolts.
Fig. 160: Removing Lower Engine-To-Transaxle Bolts
Remove the transaxle assembly.
Fig. 161: Removing Transaxle Assembly
Installation
Fig. 162: Installing Transaxle Into Vehicle
Install the lower engine-to-transaxle bolts.
Tighten
Tighten the lower engine-to-transaxle bolts (a) to 75 N.m (55 lb-ft).
Tighten the lower engine-to-transaxle bolt (b) to 21 N.m (15 lb-ft).
Tighten the lower engine-to-transaxle bolt (c) to 31 N.m (23 lb-ft).
Fig. 163: Installing Lower Engine-To-Transaxle Bolts
Install the rear transaxle mounting bracket bolts (a).
Tighten
Tighten the rear transaxle mounting bracket bolts (a) to 62 N.m (45 lb-ft).
Install the damping block connection bolt and nut (b).
Tighten
Tighten the damping block connection bolt and nut (b) to 68 N.m (50 lb-ft).
Fig. 164: Installing Damping Block Connection Bolt And Nut
Install the torque converter bolts.
Install the starter motor. Refer to "STARTER REMOVAL AND INSTALLATION :".
Install the drive axle. Refer to "DRIVE AXLE ASSEMBLY REMOVAL AND INSTALLATION: For Automatic Transaxle".
Fig. 165: Installing Torque Converter Bolts
Install the oil cooler pipes from the transaxle. Refer to "OIL COOLER PIPES/HOSES REMOVAL AND INSTALLATION:".
Lower the vehicle.
Fig. 166: Installing Oil Cooler Pipes From Transaxle
Install the left transaxle mounting bracket. Refer to "LEFT TRANSAXLE MOUNTING BRACKET REMOVAL AND INSTALLATION:".
Fig. 167: Installing Left Transaxle Mounting Bracket
Install the upper transaxle-to-engine bolts.
Tighten
Tighten the upper transaxle-to-engine bolts to 75 N.m (55 lb-ft).
Fig. 168: Installing Upper Transaxle-To-Engine Bolts
Install the clips to the shift control cable and connect the shift cable.
Fig. 169: Installing Clips To Shift Control Cable And Connecting Shift Cable
Install the park/neutral position switch electrical connector.
Connect the transaxle wiring harness to the transaxle.
Fig. 170: Connecting Transaxle Wiring Harness To Transaxle
Remove the engine support fixture DW110-060.
Install the battery. Refer to "BATTERY AND BATTERY TRAY REMOVAL AND INSTALLATION :".
Add the transaxle fluid. Refer to "TRANSAXLE FLUID LEVEL CHECKING PROCEDURE:".
Apr 30, 2010 at 5:51 AM
