2004 Suzuki Forenza
AXLEROD
  • 2004 SUZUKI FORENZA
  • 4 CYL
  • FWD
  • 65,700 MILES
How to change brakes
Monday, March 16th, 2009 AT 7:18 PM
DAVE H
  • 13,384 POSTS
FRONT DISC BRAKE PADS
Removal
Raise and support vehicle. Mark position of front wheel relative to wheel hub to preserve wheel balance. Remove front wheel.
Remove lower caliper sliding pin, and loosen upper caliper sliding pin. Rotate caliper upward, without disconnecting flexible brake line from caliper.
Remove brake pads. Measure pad thickness. Replace pads if not within specification. See DISC BRAKE SPECIFICATIONS .
Installation
If new pads are installed, use syringe to remove some brake fluid from reservoir. Using appropriate tool, push in caliper piston. Install pads.
Pull caliper downward, without damaging piston dust seal. Install lower caliper sliding pin. Tighten caliper sliding pins. Align marks during wheel removal and install front wheel. Tighten wheel lug nuts.
REAR DISC BRAKE PADS
Removal
Raise and support vehicle. Mark position of rear wheel relative to wheel hub to preserve wheel balance. Remove rear wheel. Remove lower caliper sliding pin, and loosen upper caliper sliding pin. Rotate caliper upward, without disconnecting flexible brake line from caliper. Remove brake pads. Measure pad thickness. Replace pads if not within specification. See DISC BRAKE SPECIFICATIONS .
Installation
Pull caliper downward, without damaging piston dust seal. Install lower caliper sliding pin. Tighten caliper sliding pins. Align marks during wheel removal and install rear wheel. Tighten wheel lug nuts. See TORQUE SPECIFICATIONS .
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_379.png
Wednesday, April 21st, 2021 AT 2:23 PM
