2003 Suzuki Aerio Remounting Transmission
180,000 MILES • 4 CYL • 2WD • MANUAL
DANKAT1966
Having changed the clutch (complete clutch including pilot and thrust bearing), I am trying without success to remount the transmission to the engine. This is what I have don so far.
1) After getting the transmission in place (there is on stud that the transmission is guided into place with) I tried to manually press the transmission and engine together, but it would not budge. So I went to 2) with all the bolts that connect transmission to engine lined up correctly I tightened them up gradually one at a time so as to keep the gap at bottom and top, back and front constant. This still did not close up the gap, as it gets to the point where they will not tighten any more. because I thought that we may not have lined the shaft up correctly, I took the transmission off to check. It seems to be lining up. But will not close. Step 3) Email someone who may recognize what I am doing wrong, or of there is a technique or trick I could use to somehow get the transmission back on. Note: I am using an engine hoist that is secured to the engine and the car is on stands in the flat garage.
Aug 17, 2010 at 4:15 PM
DOCFIXIT
  • 18,828 POSTS
Hi Did kit come with a pilot input shaft to line up disc?
Aug 18, 2010 at 4:23 AM
DANKAT1966
Yes came with shaft allignment tool. Checked and double checked allignment. The shaft seems to be alligned but to clarify my previous post, i am about 1/2 - 1/3 inch away from closing the gap between trans and engine.
Aug 18, 2010 at 5:35 AM
DOCFIXIT
  • 18,828 POSTS
Has to be alignment with pilot bushing even with tool it can be off. feel around clutch cover area between bolts is dics even all the way around? if not loosen cover use tool to wiggle disc into position so tahe when cover tight toolslides out easy. If using a jack on trans once you engage input shaft to disc backoff jacj and manhandle trans on to engine . kinda of wiggle push bounce.
Aug 18, 2010 at 6:21 AM
