Suspension
2004 LAND ROVER
100,000 MILES • 4.8L • V8 • 4WD • AUTOMATIC
CONQUEROR
  • 40 POSTS
I just replaced the two front Air Suspension of My Range Rover 2004 model. But I noticed that the Left Side Deflates Faster. I noticed that there is no Air again in the Left side Air suspension the following morning. Please, any solution to this problem. Please note that, there is no "hiss" sound at all. The Air Suspension goes up anytime i start the engine after 1 to 2 hours. What do i do now?
Jul 8, 2016 at 3:15 AM
HMAC300
  • 48,601 POSTS
get a spray bottle with soapy water and check around for an air leak by spraying lines etc. if no leakage it may be the pump unit and a valve is sticking open. that will require a scan by a local mechanic to check to see if it is.
Jul 8, 2016 at 5:22 AM
