surges when hot, no engine codes when checked
150,000 MILES
BRADSCH
Happened on the wifes van the other day,was bout 85 F so not hot yet, she was on the hiway and it started surging. I have looked it over,haven't seen or smelt anything burning.took it to advanced auto parts and they put a code reader on it,and there was no code for the engine what so ever. thought bout plug wires,speed sensor,ecm or ignition module. just don't want to spend money or time on the wrong thing. anyone know what this is? thank you.
Apr 21, 2013 at 3:26 AM
first, check actual fuel pressure as if it is low it wil cause this condiion.
have the cat converter back pressure checked as well for a clogged cat converter
the torque converter will do this as well in the trans but usually codes when it fails.
Apr 21, 2013 at 3:44 AM
BRADSCH
Thank you ASEMaster6371 for the reply. I did forget to mention that it has happened only the one time.I took it for a 10 mile ride yesterday and it ran just fine in the city and on the hiway.
Apr 21, 2013 at 11:26 PM
