2001 Subaru Outback sunroof hitting a metal bracket.
SRWILSON
Interior problem
2001 Subaru Outback
The second sunroof sounds like it is hitting a metal bracket when I try to open it. The sunshade does the same thing. My question is how do I remove the 'plastic gromets' that hold the roof liner to get at the problem? What is the metal bracket for?
Thanks
Scott Wilson
Jul 14, 2008 at 2:56 AM
KHLOW2008
  • 41,812 POSTS
Hi Scott,
Thanks for the donation.
If the grommet is the flat type, you need to pry it off with the aid of a flat thin screwdriver on either side. It is plugged in.
I do not know which bracket you are refering to but there is a wind deflector plate, it pops out slightly when the glass is opened.
Jul 14, 2008 at 4:08 AM
