2001 Subaru Outback Hesitation
2001 SUBARU OUTBACK
10,450 MILES • 4 CYL • AWD • MANUAL
PVACCO
I have a 2001 Subaru Outback wagon. Manual Trans. with 104,500 miles. Since about 95,000 miles (only when the engine is up to operating temp.) it will hesitate and "buck" if given gas too quickly. It is as if the gas fuel mixture is not correct and the engine is fighting to adjust. If I accelerate solely then I don't notice the bucking.
Car idles fine and accelerates well when the engine is below normal operating temp. No check engine light has come on. No codes are obtained when the vehicle is checked.
Fuel filter has been replaced, plugs only have about 20,000 miles on them, new timing belt, water pump, temp. gauge etc. were put on this weekend. No improvement in car performance.
Any suggestions would be helpful.
Mar 17, 2008 at 8:44 AM
PVACCO
I figured I would update this post with my own answer.
I finally got the check engine light to come on and it indicated a cylinder misfire. I replaced the spark plugs and put on a new set of wires and the car runs like new.
Apr 22, 2008 at 1:54 AM
