Transmission slips the first time shifting?
2000 SUBARU OUTBACK
105,000 MILES • 4 CYL • AWD • AUTOMATIC
NEALM51
when it is cold (30 deg or less) it slips the first time though , then it shifts fine after that . if it is kept inside it shifts fine . i changed the fluid and filter . so whats up?
Dec 13, 2007 at 11:42 AM
LOSTINMARS
  • CERTIFIED EXPERT
  • 222 POSTS
what's up is those transmissions are not all that good. yours is on the decline. prepare to spend some cash soon on a rebuild.
Dec 19, 2007 at 10:33 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
I have seen the torque converter turbine speed sensor get weak and cause this problem, here is the location so you can swap it out. Check out the images (below). Let us know how it goes
Sep 10, 2024 at 5:23 PM
