1998 Subaru Outback Valve Cover Gasket Leaking Oil
BOTA1
Engine Mechanical problem
1998 Subaru Outback 4 cyl All Wheel Drive Automatic
Subaru dealer quoted me $300 to change leaking valve cover gaskets. I thought this was pretty steep. How much should it really cost? Thanks.
Oct 12, 2008 at 9:20 AM
  • 31,937 POSTS
Hi there,
Wow, well if that is the going price there i will move my work shop to your location, I would get a price from an independent mechanic, you can use after market gaskets with out any problem and they should take less than 1 Hr to replace as i am in Australia i am unsure of the actual prices but doing a quick conversion i would be saying they should be doing it foe a lot less.
Mark (mhpautos)
Oct 12, 2008 at 10:51 AM
BLACKOP555
  • 10,386 POSTS
unless hes replacing the gasket with gold leafs hes overcharging you. should not be that much. 1 hour labor max.
i would like to see what hes charging you and for what.
