1996 Subaru Outback timing belt damage
LAFRIEDMAN
  • 1996 SUBARU OUTBACK
Engine Mechanical problem
1996 Subaru Outback 4 cyl All Wheel Drive Automatic
My 1996 Outback died while my wife was driving it - it just stopped running and shut off. We had it towed to a Subaru dealer who said the tiiming belt broke. Additionally, he said that this usually results in a bent valve. Is this true? If there is a chance that only the timing belt is broken, I would have it fixed. The mechanic said, however, that it is impossible to rule out engine damage without replacing the timing belt. Is all of this correct? It's not worth fixing if there is engine damage.
Monday, September 1st, 2008 AT 2:28 AM
  • 31,937 POSTS
Hi there, Thank you for the donation,
The table in the pic gives you a list of engines and if they are interference or not, interference engine will have valve damage. check for your engine and if it is an interference type at best the engine will have to be removed and the heads dismantled for valve replacement.
Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_snap_1_25.jpg
Monday, September 1st, 2008 AT 5:39 AM
