1996 Subaru Legacy Overheating
1996 SUBARU
ANDREW07
i have a 96 subaru legacy wagon with around 150000 miles on it. It has intermittent overheating problems (every couple of weeks). The radiator and thermostat were replaced about 2 months ago, i understand one cause of the overheating besides problems with the head gasket is not properly bleeding/burping air from the system when coolant is refilled. Would air have worked its way out after 2 months or could this still be a problem? How do I tell if this is the problem and how do i fix it if it is?
Aug 9, 2007 at 5:58 AM
  • 75,988 POSTS
[quote:1b27c51953="andrew07"]i have a 96 subaru legacy wagon with around 150000 miles on it. It has intermittent overheating problems (every couple of weeks). The radiator and thermostat were replaced about 2 months ago, i understand one cause of the overheating besides problems with the head gasket is not properly bleeding/burping air from the system when coolant is refilled. Would air have worked its way out after 2 months or could this still be a problem? How do I tell if this is the problem and how do i fix it if it is?[/quote:1b27c51953]
Try re-bleeding it again
BLEEDING COOLING SYSTEM
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Aug 11, 2007 at 11:17 AM
Suggested Repair
Re-bleed the cooling system: set the heater to maximum heat, drain and refill with a 50/50 coolant mix, open the bleed bolt until coolant flows without bubbles, then run the engine to operating temperature with the radiator cap off and top off as needed.
Conversation Summary
The owner of a 1996 Subaru Legacy wagon with about 150,000 miles reports intermittent overheating every couple of weeks. The radiator and thermostat were replaced two months earlier, and the owner asks whether trapped air from improper bleeding could still be the cause and how to check and fix it. The expert recommends bleeding the cooling system again and outlines the bleed procedure.
