Scanner won't scan engine.
SUBARU
ANOELJR2002
Car: 1998 Suburu Forester
My engine light turned on. I went to my mechanic and they claim the connector on my car did not have power. They got power to the connector and claim there was not enough ground to the connector, however, they say the scanner still doesn't scan the car. I am supposed to bring the car back on Friday when I can give them more time. The engine light continues on. The car runs fine. I believe they said their scanner is from Snap-On-Tools. Is their compatibility issue here? What do you think the problem could be?
Thanks, I don't want them to mess up the computer if that is possible. :cry:
Mar 21, 2006 at 11:31 AM
WRX246
  • 39 POSTS
My suggestion is that they are using the wrong adaptor OR THEYRE NOT USING THE CORRECT SUBARU SELECT MONITOR WHICH IS DESIGNED TO READ THE COMPUTER . IF I WERE YOU FIND SOMEONE WHO HAS ONE & ASK THEM TO DO IT.
i'VE NEVER HEARD OF A CONNECTOR HAVING NO POWER.Thanks
Aug 3, 2007 at 9:13 AM
