Overheating Subaru Legacy Outback 1995
TIMPANELLIJ1
  • 1995 SUBARU
I have an Subaru Legacy outback, it has about 194,000 miles on it and it started overheating when it was at about 190,000 miles on it. I changed the radiator and it was okay for a while but began to over heat again. I changed the hoses on it to see if that helped but nothing. When I looked at the coolant it had some kind of grayish texture to it and there was sometimes little chunks of it in it. I flushed out the radiator and hoses and it did nothing but get the greyish texture out of it. I changed the head gasket already and the thermostat 3 times but still it like to suddenly overheat. I recently took out the thermostat and now it doesn't over heat but now I have no heat and that no fun in the winter. Is there anything I can do to help fix this problem with the overheating?
Friday, December 22nd, 2006 AT 5:25 PM
MATHIASO
  • 1,209 POSTS
Put the thermostat back and check your coolant temperature sensor
Saturday, December 23rd, 2006 AT 8:54 PM
TIMPANELLIJ1
I Have already checked the senors they seem to be fine because the fans are running properly. Are there any other suggestions?
Monday, December 25th, 2006 AT 4:21 PM
Related Engine Overheat Content
