1986 Subaru GL EGR Light On
SUBARU
RANDYSSUBARU
I have a 1986 Subaru Wagon with 240,000 miles. It is a stick shift, 4 wheel drive and the EGR light just came on when it rolled over to 240,000. From past experience from a repair manual for idiots I found at the library you just unplug a connector under the dash and plug it into another. It has been almost 10 years since I have done this and I can't remember the colored plugs you exchange. This is because I am assuming the EGR valve is OK because the car runs great and the light came on automatically as the mileage rolled over. Can you help me?
Jul 24, 2007 at 9:03 AM
2CARPRO JACK
  • 11,533 POSTS
I will need the model of your Subaru to look it up, ie... DL , GL, RX ?
Jul 25, 2007 at 12:51 AM
RANDYSSUBARU
the model is a GL
Jul 25, 2007 at 3:03 PM
2CARPRO JACK
  • 11,533 POSTS
remove left cover under instrument panel.Unplug from blue and plug it into the green connector
Jul 26, 2007 at 12:55 AM
Suggested Repair
Remove the left cover under the instrument panel, unplug the connector from the blue connector, and plug it into the green connector.
Conversation Summary
The owner of a 1986 Subaru GL wagon said the EGR light came on at 240,000 miles even though the vehicle still ran well, and recalled swapping connectors under the dash. After confirming the model is a GL, the expert advised removing the left cover under the instrument panel, unplugging from the blue connector, and plugging into the green connector.
