2006 Subaru SMELL HOT
2006 SUBARU
17,000 MILES • 4 CYL • AWD • AUTOMATIC
SWAMARINE
Just bought a '06 Subaru Outback Wagon 2.5i After driving it the first time I noticed it smells like its running hot. I notice this after shutting down and getting out. I can also here that crackling sound from the engine when its off. Should I be concerned? Do all cars make that sound? I know my Honda doesn't.
Dec 4, 2007 at 10:22 PM
98RANGERXLT
  • CAR REPAIR CONTRIBUTOR
  • 301 POSTS
The voltage regulator on your truck is in the alternator it is not replaceable try putting a new one on remans are usually no good out of the box
Oct 9, 2007 at 10:17 PM
  • 31,937 POSTS
Hi there,
There is a great deal of tin work around the subaru exhaust system, so there is a bit of noise and movement when it cools down, as for the smell, you may have a small oil or coolant leak dripping onto the exhaust. have a good look around and see if you can identify any leaks, if in doubt take it to your mechanic for an inspection.
Mark (mhpautos)
Dec 5, 2007 at 2:42 AM
