1996 Legacy Outback diagnosis
1996 SUBARU
MOUNTAIN_MAN_MIKE
I own a 1996 Subaru Legacy Outback, 2.5L, automatic that is giving me problems. I connected an OBDII scanner and it showed 1) P0130 O2 circuit malfunction 2) P0400 EGR flow malfunction and 3) P0740 TCC Circuit malfunction. After writing down the codes I erased the codes and the check engine light went out. Also, the car drove like it should the entire 14 mile commute to work. At that point the check engine light came on again. When I connected the scanner again it displayed the same O2 circuit code, but no other codes. In as much as the codes reflect a problem with the circuit I am wondering if there might be a problem with the computer module. Any suggestions?
Jun 5, 2007 at 11:40 AM
WRX246
  • 39 POSTS
what is your car doing thats causing problems
thanks
sales@dargavilleprint.co.nz
Jul 15, 2007 at 1:17 PM
MOUNTAIN_MAN_MIKE
The car has an extremely hard shift 1 to 2 and frequently, but not always downshifts at highway speeds. I took my car to the Subaru dealer and had them scan it, showing an O2 sensor, coolant temp sensor and tortuq converter clutch solenoid problem. I replaced att three components and the car drove like a dream, for about 20 miles. The check engine light reappeared and the same driving characteristics also reappeared. I am starting to think the onboard computer is out of whack. My eldest son did crack the car up several years ago, setting off the airbag. I did not replace the airbag due to the expense.
Jul 16, 2007 at 7:01 AM
WRX246
  • 39 POSTS
i'm picking your car is automatic????
i'll have a check in my subaru manuals & come back to you
if you have your email address i could proberly email you direct
my email is carlisa123@gmail.com
thanks
carlisa
Jul 16, 2007 at 7:48 AM
MOUNTAIN_MAN_MIKE
It is indeed an automatic, along with Legacy Outback, 2.5L to complete the description. I am wondering if the computer is bad or maybe a bad ground somewhere that might be causing a false reading.
Jul 16, 2007 at 7:56 AM
WRX246
  • 39 POSTS
hello mike
check your email for one from me
thanks
carlisa
Jul 16, 2007 at 1:20 PM
