1992 Subaru Loyale No reverse
1992 SUBARU LOYALE
103,000 MILES • 4 CYL • FWD • AUTOMATIC
RKHMAINE
I just got a car from a co-worker. a 1992 Subaru Loyale, w/ 103K miles. She got stuck in a snow bank, and "rocked" it out. Now the reverse doesn't do anything. AND the car now moves in neutral ! (it seems to be in 1st gear) I thought bent linkage, but I cant tell. When slowly shifting between positions, reverse doesn't work anywhere. BUT in between reverse and PARK the car trys to move forward again.
Mar 20, 2010 at 2:08 PM
KHLOW2008
  • 41,814 POSTS
Hi rkhmaine,
Thank you for the donation.
It is possible the shift cable or linkages have been damaged causing the shift positions to be out when shifting into position.
Get the cable and linkages checked first.
Alternatively the transmission is bad, one of the clutches inside the trans has failed and when this occurs, you would not have any reverse.
Mar 20, 2010 at 10:46 PM
