1997 Subaru Legacy Cylinder
1997 SUBARU LEGACY
211,000 MILES • 4 CYL • 4WD • AUTOMATIC
KECLARKE
I did a diganosis test and I get a P0304 code. My cylinder 4 misfire detected. How can I fix this problem. I'm a certified Michanic of 15 yrs, but I've not done this work in a few yrs. Please help me fix my problem. Kristine
Sep 10, 2010 at 7:39 AM
Hi keclarke, Welcome to 2carpros and TY for the donation
P0304 Start by checking no.4 sparkplug, compression and injector
Sep 10, 2010 at 9:19 AM
KECLARKE
I did check all those things and I still get the same diognostic code. Lastnight, my check engine light came on and I did the diognostic test and it said p0304 again. What else could it be that is causing the misfire?
Sep 10, 2010 at 11:17 PM
What's the compression reading on no.4 If all of these components tested good-possibly a wiring problem or the computer itself-Did you check the plug wire and coil resistance for this cylinder
Sep 11, 2010 at 1:00 AM
KECLARKE
The compression of the no. 4 is about 90 psi. That should be enought to fire. I also checked to wiring and seem to have spark. I'll check to coil resistance of the cylinder. If all that pans out, could it be a possible lifter problem? Thanks.
Sep 11, 2010 at 3:23 AM
With that mileage -Hard to say on the lifter also try checking the no.4 injector resistances. Did you replace all the plugs
Sep 11, 2010 at 3:28 AM
KECLARKE
I replaced the no. 4 injector and no. 4 plug. I'll have to look at the coil resistance.
Sep 11, 2010 at 3:39 AM
KHLOW2008
  • 41,814 POSTS
Compression pressure service limit is 128 psi. at 90 psi the compression pressure is too low and can result in misfiring.
Check the valve clearance. If it is too tight, it can result in pressure loss.
Sep 19, 2010 at 6:30 AM
