Transmission problem
2002 Subaru Impreza 4 cyl All Wheel Drive Manual 135 K miles
Hello, when I am driving my car, it shifts from gear to gear just fine, but when I try to accelerate quickly, it seems like the clutch is not engaging, and when I hit the gas to accelerate with the clutch pedal all the way out, the rpm's rev up, but the car does not speed up unless I accelerate very slowly. Even then, if I am heading up a hill or something, it will rev up, but seems to do it less on flat surfaces. It seems to do it more in the higher gears, but does it in as low as 3rd gear when I and heading up a hill. Hasn't happened in 1st gear, but seems to be getting a little worse. Does this mean that my clutch is going out, or can I adjust the clutch so it engages sooner when I release the pedal? Thanks!
Dec 9, 2009 at 12:23 AM
