1999 Subaru Impreza gas filler neck leaks
1999 SUBARU IMPREZA
13,200 MILES • 4 CYL • AWD • AUTOMATIC
JONLEF
  • 6 POSTS
Thanks for taking this question.
The car belongs to me but my daughter has it in Vermont where she lives so I haven't seen the problem. She says the gas filler neck leaks about 2 cups of gas onto the ground when I fill the tank. In 46 years of car ownership and repair, I've never had a car do this. Is this a common problem with Subarus and what do you recommend I do to repair it most economically and effectively.
Thanks much for your reply. John
Oct 27, 2009 at 9:44 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
You may have a problem with the tank purge? vent system, this can cause airlocks in the filler and fuel to back up and spill, this may entail the removal of the fuel tank, i will see what information i can find for you and i will post it here.
mark (mhpautos)
Oct 27, 2009 at 11:22 PM
JONLEF
  • 6 POSTS
The tube is rusted around the top and leaks gas if the nozzle isn't fully inserted. Does the whole tank need to be replaced or can the filler tube be replaced?
Oct 28, 2009 at 1:01 PM
  • 31,937 POSTS
Hi there,
I will have to look into this for you.
Mark
Oct 28, 2009 at 4:26 PM
JONLEF
  • 6 POSTS
Mark, ok, thanks for looking into a solution,
John
Oct 30, 2009 at 8:13 AM
