1998 Subaru Impreza CVC Boot-Axles
BRIEN
  • 1998 SUBARU IMPREZA
  • 4 CYL
  • AWD
  • 14,300 MILES
I had a CVC Boot tear and leak grease. I put in more grease and a patch until I could afford a proper fix. The car operates fine. I am going to replace the Sub-Axle on that side. (Passenger Side). Is there anything else you would reccomend?
Thursday, April 29th, 2010 AT 2:12 PM
MERLIN2021
  • 17,250 POSTS
You put a patch on the boot? This does not usually work. The convolutions on the boot force grease back into the joint as you drive, if they are deformed, the joint wont be properly greased, and could fail sooner.
Thursday, April 29th, 2010 AT 2:22 PM
Related General Content
