1987 Subaru GL cooling fan relay
1987 SUBARU GL
134,000 MILES • 4 CYL • FWD • MANUAL
WEEKSY
my 1987 subaru gl hb is a 1.6 5-sp,car is mint in and out.(note the mileage)in traffic she almost red lines the temp,i noticed the fan wasnt flipping on.the fan itself works being tested on battery,fuses are all ok,where can i find the right relay or a good schedmatic for a guide on the wiring harness?im car saavy but this is an original japan car.temp switch?broken wire?relay?looking for a starting point.momma doesnt want a toggle switch.
Aug 21, 2009 at 1:19 PM
Test the thermostat if okay -check and test the coolant temperature sensor or the engine temperature gauge switch computer might not be picking up its input signals therefore not activating the fan relay to fire up the fan motor. I don't blame her-she might forget about it and end up draining the battery then you're in big time trouble Why not tie it in on an ignition switch power
Aug 21, 2009 at 3:59 PM
