2001 Subaru Forester Confuse
2001 SUBARU FORESTER
141,000 MILES • 4 CYL • AWD • AUTOMATIC
UNKNOWNGUY_5
[img:95a7d69464]http://www.2carpros.com/forum/automotive_pictures/555428_ring_and_shaft_end_1.jpg[/img:95a7d69464]
started changing cv shaft i was about to replace the shaft but i notice a spring looking O ring was sticking out im trying to find out where does it go and if it goes inside de gap where the shaft goes will it fall down all the way or will it stay there while i put the shaft in.
Jul 27, 2010 at 5:19 PM
EDWARD.S
  • 166 POSTS
Hi,The One Snap Ring On The End Of the shaft Is The Only Thing That Should Be On there.It Goes In the Groove.Where Did The other Ring Come From?Was That On The New Shaft Or Old Shaft?
Hope This Helps You,
Edward S.
Jul 27, 2010 at 10:08 PM
