2000 Subaru Forester checkengine light
84,000 MILES • 4 CYL • 4WD • MANUAL
MAMAHAN
In june, Suburu replaced the knock sensor (code P0328).But now the engine light has been showing off and on for the past week.It was a $318 repair and didn't work. The light went off once when I
tightened the gas cap, But it has been off and on since then. Any theories?
mary ann
Sep 6, 2008 at 3:07 AM
STPETEKIDD
First check the connection to the sensor there are two ends that connect Then if thats O K you should go to a local auto parts store and have them put thier hand held comp for check engine lights (most do it complementary) and have them reset the computer, then drive it, then if the problem continues I would see the shop that put in the sensor
Apr 1, 2009 at 7:40 AM
