1998 Subaru Forester Stalls at random, any speed, any time
DHARMASHIV
  • 1998 SUBARU FORESTER
  • 4 CYL
  • AWD
  • MANUAL
  • 205,000 MILES
The car was unused for about 4 weeks. Upon driving it again, it began to stall at random, typically once in a 50 KM trip. The engine slows and seems to lack power. When you put your foot on the gas, the engine balks then dies. Turning off the ignition and restarting is fine. The engine then runs smoothly and I am able to continue driving until it stalls again 5 to 15 minutes later.
The initial engine code was 0304. I R and R'ed that plug but the problem persisted. Since the symptoms appaered fuel system related I have done a number of things diagnosticly and replaced parts.
-new fuel filter: no change
-new fuel pump: no change
There is no smell of gas. The fuel pressure regulator is behaving normally. Fuel system pressure is within tolerences. No codes are shown when the reader is attached when driving. The car starts fine and idles smoothly and at the correct RPM even after warm up.
Sunday, June 6th, 2010 AT 12:42 PM
HIMILE98FORESTER
I have the same problem over several years, increasingly so with time. Always when engine is hot. Changed coil, fuel filter, fuel pressure checked out okay. It happens instantly, then when it dies, engine starts right back up as if never a problem. Razmatazz suggested the camshaft position sensor, or the fuel pump relay fuse. Haven't tried those yet. Let me know if you find a solution.
Tuesday, August 31st, 2010 AT 1:31 PM
DHARMASHIV
In my case it turned out to be the MAF. For a full run down on what I did see the thread on SubaruForester. Org
Tuesday, August 31st, 2010 AT 6:16 PM
