Stuck in gear, engine starts, wheels locked
23,000,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
PETE LONG2
I reversed out of a road to turn round, bumped the curb with my rear tire (front wheel drive) couldn't get van out of reverse. Got a tow but he had to slide front tires up ramp even with clutch depressed wheels wouldn't roll. Visually looked at gear linkage top and bottom, all moving and no linkage seems to be loose.
May 14, 2019 at 6:13 PM
  • 55,628 POSTS
Lets raise the front front he car and check the wheel individually. Here is a guide to help you get started:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
May 16, 2019 at 4:51 AM
PETE LONG2
Hello Ken, thanks. I have now had a report back that it is my linkage that is at fault. The garage managed to get it out of gear and get it on the ramps. Bits ordered from Peugeot, so hopefully I will soon be back on the road. :)
May 16, 2019 at 8:45 PM
  • 55,628 POSTS
Sounds like you found it, please let us know how much it was to fix.
May 17, 2019 at 8:33 AM
PETE LONG2
Parts ordered are no longer available so we will have to try to source elsewhere or do some sort of 'bodge' to repair the worn linkage. Will keep you updated.
May 17, 2019 at 11:16 PM
  • 55,628 POSTS
Please do.
May 18, 2019 at 4:13 AM
