Stuck brake caliper
283,000 MILES
PAULKLEE
Replaced brake pads.
Caliper wouldn't allow wheel to fit.
Pressed brake pedal until caliper grasped rotor.
Now brake won't release.
Mounting bolt go through a sleeve that wouldn't slide. Had to use a c clamp to push them in.
Not sure I can get it back apart.
What needs to be replaced?
How do I do that?
Apr 14, 2013 at 6:20 PM
replace the mounting bolts. as far as the caliper, if you had to use a c clamp. i sugest replacing the caliper and the brake hose as you have a restriction here
Apr 14, 2013 at 6:29 PM
PAULKLEE
Is it possible to replace the rubber sleeves that the sliders operate in?
I cleaned up the bolts and the seem to be ok.
They slide in the barrels but the silver barrels are not sliding in the sleeves.
Apr 14, 2013 at 6:34 PM
it the larger ones that must slide freely. remove them, clean them up and try to clean them
Apr 14, 2013 at 7:07 PM
