Hi guys, i have another problem for you. l have the car listed above that has a stripped bolt. After doing the timing belt and guides the chain guide bolt stripped out.This model you can access that bolt thru a plug that is part of the head.They make a replacement bolt for the guide that bolts into that plug hole.That happens to be the hole that is stripped now. My question is, do they make anything to repair those threads like helicoil or inserts? I really do not want to replace the head.Thank you in advance for any help.
Dec 25, 2018 at 11:35 AM
