Stops running when transmission is shifted into gear
150,000 MILES • 0.5L • 6 CYL • TURBO • 2WD • AUTOMATIC
SHREE42
When I crank the car it runs fine but when I put it in gear it shuts off.
Aug 3, 2020 at 11:46 AM
  • 110,251 POSTS
When it stalls, does it seem to be lurching forward or backwards or does it seem like a low idle related issue?
If it seems to be idling low, first check for engine vacuum leaks. Here is a link that shows how it is done:
Also, is the check engine light staying on when it is running? If so, you need to have the computer scanned. Most parts stores can do a basic test, but since the vehicle isn't driveable, see if you can find a parts store that will lend or rent one to you.
Here is a video showing how to scan the CAN bus system. CAN stands for computer area network This type of scan will check all modules in the vehicle.
https://youtu.be/InIlnsjOVFA
Aug 3, 2020 at 2:40 PM
SHREE42
Okay, when I crank it it will idle but when I put it in gear reverse neutral drive it shuts off.
stacy
Aug 4, 2020 at 5:51 AM
  • 110,251 POSTS
Hi Stacy,
When it idles in neutral or park, can you rev the engine? Also, does it just shut off or does it feel like the vehicle jumps forward?
Aug 4, 2020 at 3:16 PM
