steering wheel replacement
113,000 MILES • 4 CYL • 2WD • AUTOMATIC
TWESTRICK
I'd like to replace the steering wheel and stereo head unit on my Rogue with one from a higher trim rogue. Is the wiring there from the factory to connect the different accessories that are on the steering wheel that aren't on the current wheel and are the connections the same for the head unit?
Mar 19, 2019 at 8:07 PM
  • 110,248 POSTS
Welcome to 2CarPros.
The required wiring will not be there. The different trims are manufactured specifically for the specific components involved. To confirm this, I checked out schematics for different components and the base models don't show the same design.
I wish I had a better answer, but that is the bottom line.
Mar 20, 2019 at 12:51 PM
