Steering wheel makes a noise when I turn
114,000 MILES • V6 • 2WD • AUTOMATIC
MIKEMV
It makes a clicking noise or grinding noise when I turn left or right. It does not make noises while I am driving or sitting still only when I turn left or right. But it does make the noise if I am sitting still and then turn the wheel. Anyone have an idea of what it could be? Please and thanks.
Feb 19, 2018 at 8:32 AM
Good morning.
I would have the axle shafts checked in the front. There are boots that protect the joints. When the joints wear out, they make noise indicating the axle needs to be replaced.
Feb 19, 2018 at 8:05 PM
MIKEMV
Okay thanks. if I jack the car up and pull the boot back will I be able to see if it is wearing down or needs replaced?
Feb 19, 2018 at 9:26 PM
I would not recommend doing this operation.
Take it to a shop and let them check it for you. Most shops will do the checks for free.
Feb 19, 2018 at 9:29 PM
MIKEMV
Okay thanks, I appreciate it.
Feb 20, 2018 at 12:46 AM
You are welcome.
Feb 20, 2018 at 12:47 AM
