Steering wheel jerks 30-40 MPH
120,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
ACUNNINGHAM1285
At 30 -40 MPH the steering wheel jerks to off center and then stays that way but drives fine. As it jerks the car "swerves" to the right slightly and then drives fine.
If I slowly accelerate it happens at lower speeds. If I accelerate quickly it can happen as late as 55 MPH.
It happens every time I accelerate from a stop.
4-5 months ago I replaced passenger lower control arm as the ball joint was bad and both front wheel hubs. Passenger hub was bad and grinding. I replaced both sides.
May 11, 2021 at 12:03 AM
CARADIODOC
  • 34,407 POSTS
What you're describing is commonly caused by a loose rack and pinion steering gear. Yours uses two bolts on the driver's side, so rather than just one to come loose, I'd more likely expect to see the rubber bushings have deteriorated, allowing the steering gear to slide back and forth. There's a rubber sleeve on the other end, so that doesn't hold the gear from sliding.\\Worn control arm bushings will cause this type of darting from side to side, but they show up continually while driving. Steering gears tend to remain a little tighter, so it takes some effort to cause them to shift position, then they tend to stay put longer.
The way to identify this is to have a helper turn the steering wheel back and forth about a quarter turn each way while you watch the steering gear. Being mounted on rubber bushings, it might move a perceptible amount, but if those bushings are worn, you'll see the gear sliding back and forth perhaps as much as a quarter inch..
May 11, 2021 at 10:42 AM
ACUNNINGHAM1285
Thank you. I will check this out tonight.
This may be a silly question. Can the bushing be changed without the gear or other parts being replaced?
May 11, 2021 at 11:40 PM
CARADIODOC
  • 34,407 POSTS
I don't see the bushings listed in my usual sources, but there are other alternatives. First, check at the dealer's parts department. For all brands of cars, you'll typically only find the accordion boots available through the dealer. Inner tie rod ends were not, but they were available from the auto parts stores. Sometimes you'll find rack and pinion rebuild kits, but that isn't common. Special tools are needed. There's liability concerns if something is done incorrectly, and professionally-rebuilt gears cost very little today compared to 20 years ago.
With that in mind, the mounting bushings aren't part of the critical internal system, so they may be available without buying a whole new steering gear. If you can't find replacements anywhere, the next solution is to harvest a pair from a salvage yard. You can find them in a pull-your-own-parts yard, or ask to get them from a "core" assembly. Salvage yards collect these types of assemblies and sell them to the rebuilder companies. There's no way a rebuilder is going to sell a rebuilt gear with old bushings. Since they're going to be replaced, the core doesn't lose its value if the old ones are removed.
May 12, 2021 at 10:05 AM
